Why is my ds lite not reading cartridges I put in it?
My ds lite is not reading the ds or game boy advance cartridges I put in the slots.
you may have corrosion on the copper pins in each slot. To fix this, gently apply rubbing alcohol to the corroded pins with a cotton swab. Although it is unlikely that both of the slots would have this problem, it is worth a shot.
这个答案有帮助吗?
If the above doesn't help get rid of the corrosion, try this. Get a sheet of 600 grit wet-dry sandpaper and use that to lightly sand the metal contacts.
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 495
