push start button light go's white then go's off
i thought that it was the power supply so installed a refurbsed one an did the same thing. were should i look next. nothing on the moniter almost like its still not geting power.
Here is a link to the Apple troubleshooting light meanings. If this does not help you need to find a copy of the AHT disk for your computer and try to run the diagnostic test. Are you hearing any sound--seeing any lights?
这个答案有帮助吗?
when i plug mac in i hear a type of click sound toward the plug end.when i hit on button sounds like its gona boot but dosn't. the fans start button lite gos on then off. if i let it pluged in the fans sound like they want to fly???
This is from official Apple sources
1. Reseat the video card
2. Reset the logic board ( shut down, unplug, wait 15 seconds, plug back in
3, Verify that the power cables are fully connected
4. Check for trickle voltage (see next for instructions on this and a host of other diagnostics (I just found this and it's great)
这个答案有帮助吗?
Excellent chart. +
Yes, I thought that was great. I was actually looking for the LED codes from your answer when I found it.
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 3,260
2条评论
Please let us know what you tried and the results.
由 mayer 完成的
RESEATED VIDEO, shut mac down unplug for 15 sec.. tryed again same results. i'll ck to see if the logi boards getn enough voltage
由 keith 完成的
