跳转到主内容
MacBook Pro 13寸显示器版本
9745 个问题 查看全部
My mac turns on but the screen stays black
My laptop is able to charge and turn on. However, the screen stays black. I've already tried all types of combinations, using the shift key for safe mode, using command option p and r, among others. I have no idea what to do. Should I change the battery? What can I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
We really need to know your exact machine as there are known issues on certain machines. Please go here and plug in the serial number from the back of your machine to find out what it is:
http://www.everymac.com/ultimate-mac-loo...
完成的
添加一条评论
1个答案
hello,
most likely it broke the GPU graphics card.
if you are using Apple Care warranty.
Otherwise you can try to connect an HDMI cable \ dvi \ post display and connect it to an external video so you can understand.
1- If the video on the external display works the problem is the display of your Mac to replace.
2- If the external monitor does not work the card is broken down.
There are of reeballing solutions that give good results but it becomes more a complicated welding operation at high temperatures on a motherboard with many other soldered components which can be damaged
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maryanne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 73
