跳转到主内容
加入维修社区 - 创建账户
PowerBook 1400 系列机型。于 1996 年 10 月发布。
PowerBook power on woes yet again!
I just replaced the PRAM battery of a touchy PowerBook 1400cs/133, and finally see the green "power" light glowing. I decided to leave it charging overnight to let it get some power, and this morning tried powering it on. The PB doesn't seem to be responding still, and I hear no noise or anything of the sort.
All connections to the mobo are connected properly (VGA, speaker, trackpad, keyboard).
Resetting the PRAM battery doesn't seem to be making much of a difference. The green "power" light keeps glowing, even when the charger is disconnected or the battery is pulled from the PB.
Does anyone have any ideas what could be causing this power oddity? Resetting the PRAM battery via the switch in the back isn't making much of a difference. Should I declare the PB a vegetable or brain dead and send it to the junk pile, or is there a chance of bringing it back to life?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
My 1400 starts every time when I hit the small reset button on the back, the tiny button between the two inputs on the right.
完成的
添加一条评论
2个答案
已选择的解决方案
Try resetting the PMU. Here's how to do it on your machine: http://support.apple.com/kb/HT1781
这个答案有帮助吗?
得分 2
4条评论:
I've tried that. It's not making a difference.
Perhaps there may be something else at hand here?
完成的
It's been a decade since I worked on one. Try pulling the battery and starting from the AC only. Check the AC adapter with a voltmeter.
完成的
Pulling the battery didn't work, either. I'll have to go dig out my voltmeter. Hopefully if it's just a bad AC adapter, then that'll make the rest of the fix easy enough... I just get another one! :)
完成的
Been a long time for me also. +
完成的
添加一条评论
Have you tried pulling the PRAM battery out and then starting up? This worked on my PowerBook G3 Pismo AND it worked with my PowerBook 3400. After the initial start up I can boot up without any issues, however I had to do this to both of them.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
LambdaCalculus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 1,984
