跳转到主内容
本田生产的摩托车的维修指南和支持。
Just spins when trying to start
All it does is spin when trying to start it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@rickbeenken1961 do you mean that it just turns over but does not start? What model is your Honda? What have you checked?
完成的
@rickbeenken1961 do you mean the starter spins without engaging and turning the motor over
完成的
添加一条评论
1个答案
Spins as in no compression.... Probably bent valves due to jumped timing chain or failed belt drive depending on type of drive your valve train uses (I have no way of knowing what model or age of Honda product you are referring to). My crystal ball is in the shop too, go figure.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rick beenken 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 178
