跳转到主内容
The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
26 个问题 查看全部
Upgrade screen to the i3 version of the C720?
I love this cheap (albeit plasticky) computer. It's zippy, lightweight and has a killer keyboard. The only thing I absolutely abhor is the crappy screen. Does anyone know how I can upgrade the display on this cheap fireball of an ultrabook?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
EDIT 5 June 2017: apparently this laptop uses the eDP display interface meaning it IS possible to put a different display into the laptop. Here is a reddit post with what display to buy: https://www.reddit.com/r/chromeos/commen...
all credits to joe who answered this but i thought I'd edit my answer because it is the accepted one.
Typically screens for laptops are made for that specific model, and unless your screen is somehow defective you cannot get a better quality one for your laptop. A antireflective screen protector may help though.
这个答案有帮助吗?
得分 1
5条评论:
Bugger. Absolutely not what I wanted to hear. Though, I'm interested in the antireflective protector you mentioned. What are reasons one should buy one?
完成的
Excellent! I was actually just looking some up. Thank you!
完成的
No problem! These should help a bit with the glare and be much cheaper and easier to install than a new screen.
完成的
Look for a LP116WH7(SP)(B1). This LCD is IPS and is compatible with the Acer C720(P)
完成的
添加一条评论
最有帮助的答案
As referenced here on Reddit: https://www.reddit.com/r/chromeos/commen...
The panel actually can be replaced with a higher quality LED display from Alibabba. Follow the guide posted above.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kelley Chambers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 887
