跳转到主内容
加入维修社区 - 创建账户
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
iMac won't boot - freeze at Apple logo - graphic card dead?
iMac EMC No.: 2134
Model No.: A1225
Hey guys,
since a few days my iMac won't boot anymore. After pressing the on button it is showing the apple logo and then the loading circle.
I am able to access the screen where I can select the different boot options or the bootable stick I have on via usb. But it does not matter which option I choose, it starts to load, showing the loading circle or a process bar (when trying to boot from UsB) but it freezes after a few minutes.
I also tried to access the BIOS like screen where it shows the booting process, but I wasn't able to read the problem from it.
I then brought the iMac to a local store to check it - they said that the graphic card would be dead and there were no replacement parts available. But I still wonder if this is right because the graphic card seems to be alright as the iMac is showing perfect screen and colours when accessing the hard-dive-choosing screen.
Do you have any advice how I can find out what's wrong with my iMac?
Thank you already in advance.
Best
Marvin
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If you are getting a screen the GPU is probably OK (although that is the most common issue on this machine). This sounds more like a hard drive issue.
#1 Try starting up in Safe Mode by holding down the Shift key on start up.
  1. 2 Try holding down the Command & R keys and select the repair partition on start up if you have one.
# 3 Let me know your results.
这个答案有帮助吗?
得分 1
添加一条评论
Hello mayer,
Thank you for your answer. I tried to boot in safe mode but after about 1/3 of the big status bar it changes to the round loading circle and gets stuck after about 1 minute. You can see on screenshot 1.
I also tried the CMD + R command, but it would not load anything but the loading circle with the same result as in screenshot 1.
One thing that works is to load the screen where I can select any harddrive via the ALT key on startup. But whatever I choose (Recover hard drive, Bootable USB Drive) it fails to load it. Gets stuck after a few minutes at the status bar at about 3/4.
Does this screen tell us that the graphic card is okay?
Any ideas left on what the problem could be? Or how I could find out?
Thanks for you help!
Best
这个答案有帮助吗?
得分 0
1条评论:
The screen and therefor the GPU appearing to be working just fine. I would next try that fourth icon in Safe Mode. What appears to be a mavericks system. That failing do the system installation. I do not see a repair partition, so I suspect an incomplete install or an older system on your main drive from before repair partitions were installed. This can also happen when you do a cloned installation. Do you have a backup hard drive with a system on it or another Mac you can use Target Mode with?
Also, please unaccept my answer until your problem is solved.
完成的
添加一条评论
添加你的答案
Marvin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,484
