跳转到主内容
CPU permanenttly works on half of clock
Hello everyone!
I encountered with problem and I have absolutely no idea how to resolve it.
I have an iMac mid 2011 27" with core i5-2400 (3100MHz) radeon 6970-1gb HDD 1TB .
https://s31.postimg.org/jnregi8ob/Screen...
My HDD had broken, so i decided to install SDD instead of it. So I replaced old hard disk and put ssd Crucial MX200 500Gb instead. I installed Mac OS 10.7 from scratch using embedded recovery system, and after what updated to 10.11.5.
Everything was fine until I decided pass some benchmarks. And all benchmarks show that cpu results only a half of expected. E.g Cinebench R15
https://s31.postimg.org/z28vmj2bf/Screen...
I tried to figure out what the problem and install Intel Power Gadget utility.
It reveals next - CPU frequency does not rise higher than 1600MHz even in 100% cpu load tasks. It freeze on 1.60GHz a not move even a bit. The line on the graph is absolutely flat!
https://s32.postimg.org/npa8t9bhx/Screen...
And there are no CPU overheat as all! Temperature not raises more than 50C degrees.
And GPU also work at ~20% of it power according to benchmarks (two times less points than ge-force 620m has).
I have no idea how to resolve this issue. Please share your experience in such cases
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
First take it in to an ASP and have it tested for this free repair program: https://support.apple.com/en-us/HT203787
这个答案有帮助吗?
得分 2
1条评论:
Unfortunately we have not official Apple service in our country.
And there are no symptoms described at Video Card Replacement Program. Video works fine, without artefacts and any other distortions. And everything was OK until i replaced old hdd with ssd : (
It seams to me some power management issue occurred. But i thought Intel CPU throttle mechanism works independently of os x
完成的
添加一条评论
The older MacBook models with user removable batteries were rigged to run on half clock speed whenever they were run with the battery removed from the device and with ac power. I guess something could have triggered your macOS into thinking that you “battery is removed”…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vladyslav 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 166
