跳转到主内容
How do I reset my password.
I have a laptop IBM Think Pad 42T that i have not used in years but now i need something portable. I'm old and lame with technology.......I forgot my password/authentication. I am unable to update and use it. Is there anything i can do to reset???? If i change out my hard drive and reset my password would that be all i have to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
From a Technicians point of view:
That Laptop is about 11 years old, It probably has Windows XP installed on it and the hardware would not be capable of running applications that exist now. With that being said, I would consider getting a newer laptop.
Why?:
- XP is no longer supported, so with it not receiving security patches from Microsoft, you would be vulnerable to hackers and malware.
- Even if you upgraded it to Windows 7, It would be slower then molasses on a cold day...Up Hill! and you would want to throw it out the window anyway.
Resetting the password in Windows XP: If you insist on using it.....
- Turn it on while at the same time pressing F8 continuously till you see a menu with a black background that gives you an option for SAFE MODE. Highlight SAFE MODE by using the up and down arrows of your keyboard.
- It will go into a screen that displays an Administrator account, and the account that you want to change the password to. Select the ADMINISTRATOR account and let it log in...(This account should not have a password)
- When logged in, go to Control Panel and then go to Users
- In user accounts, select your account that you want to change the password to. There should be an option to delete the password for this account.....Delet the password, then reboot the computer.
- You should now be able to log into your account and it not ask for a password.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dinosorma 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 52
