跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
iPhone won't turn on after I dropped it
Iphone won't working or turn on after i dropped it
and when i plugged it in the charger it doesn't show anything
and there is nothing on the screen
is the problem with the battery or what ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
Batteries don't easily go bad like that. Does the phone heat up in specific spots and/or does it heat up a lot in a specific spot?
Sounds like a power management ic chip has gone bad from the shock taken from dropping the phone. How far did you drop it and if you know which part of the phone did it hit on first and what surface?
完成的
there isn't any scratch on the phone !! just some small scraatch on the screen protecter but when i remove it there isn't nothing on the phone screen
完成的
添加一条评论
4个答案
Dear Mareshall Teach,
Do you hear the charging sound when plugged in?
If thats the case you could just repace the screen, or reconnect the lcd cables and try again .
这个答案有帮助吗?
得分 0
6条评论:
no i didn't hear anything
完成的
Like what Ben suggested, it might be had taken a pretty bad shock on the chip and you try could Hard Reset by holding both the Power/Top button and Home Button for about 15 seconds until iPhone turns on, if it still doesn't work, I would recommend you to visit the apple genius bar if you still had warranty.
完成的
are u sure the the problem isn't with the battery ?
完成的
The battery going bad is very highly unlikely. If you want you can replace the battery follow the instructions below:
Guide:
iPhone 5s 电池更换
Battery Part:
iPhone 5s Battery
Adhesive Strip for battery:
iPhone 5s/5c/SE (1st Gen) Battery Adhesive Strips
完成的
I dropped my phone hard on the stadium cracked phone but it had a colorful glitch and I couldn’t see my phone my dad replaced the screen but the phone shows no sign of life ? Like it won’t turn on or anything ?
完成的
显示更多的1条评论
添加一条评论
I have the same problem my phone wont charging or turning on after I dropped it
None of the buttons work even the switch and the sound when i plug the phone
My iPhone 5s dont show anything and any solution on YouTube dont work
It have a small hole just under the flash light and heat up at the same place
Photo of the phone:https://image.noelshack.com/fichiers/201...
Please help me
这个答案有帮助吗?
得分 0
1条评论:
I guess it could be the Power IC Chip that went bad.
完成的
添加一条评论
I really think that it is the Power IC because it supplys the Power to all of your components and it is very easy to damage when you drop it.
这个答案有帮助吗?
得分 0
添加一条评论
HI my name is abbass kasalany and my iphone 5s suddenly turn on and off and stop didnot charge and nothing on the screen I ve change the screen and nothing happened what the of proplem for iphone plzz give me an answer fast plzz this is my GMAIL GONDABADAO@GMAIL.COM PLZ HELP
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mareshall Teach 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 10,165
