跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Keyboard Backlight is not working properly
Hello,
My macbook pro retina 15'' is having a keyboard backlight issue.
When I boot my macbook, the backlight lights up but for about 2 seconds then shuts off right away...
Then nothing happens, tried SMC and PRAM Reset, went into the system preferences,
My F5 and F6 keys are working well because I can see I am changing the backlight illumination on my screen.
I have manage to make it work recently by closing the lid and when I open it back up, I can make the backlight work for the first 3 bars of adjustment on the screen with the F keys. If I go above those 3 bars, the keyboard backlight stop working again and I cant make it work by lowering the power again under the 3 bars I was talking about.
Macbook has never been water damage and is fully functional. Every thing has been replugged on the motherboard.
Let me know if you guys have seen this problem before, any help will be greatly appreciated. Not the biggest issue but would be nice to have this thing working back again.
Cheers!
Note: I have restored the OS to the factory settings as well, started from scratch. Doesn't seem to be a software issue. Tomorrow I will try again to de-plug and re-plug the backlight flex + try another one as well to see if its stabilizing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
have you ever resolved this issue? i also have a late 2013 15" macbook pro with a similar issue.
完成的
添加一条评论
3个答案
已选择的解决方案
Please go here, enter your serial number from the back of the machine and check to see if your machine is the early or late 2013 15" MacBook Pro.
https://checkcoverage.apple.com
If it is the Early 2013 it may be eligible for this repair extension program:
https://www.apple.com/support/macbookpro...
这个答案有帮助吗?
得分 1
1条评论:
Late 2013 I was sure about it
完成的
添加一条评论
最有帮助的答案
Keyboard backlight switches off when daylight is above a certain level. This daylight is measured by the webcam.
Is there a chance that, when you make your tests, some keyboard backlight hit the webcam and make the motherboard think the ambiant light is enough?
Can you try covering the webcam with black tape and test again?
这个答案有帮助吗?
得分 4
2条评论:
already did that couple of times
完成的
Thanks - Very Smart computer . I was reassembling and testing in full sunlight and the camera needs to be covered just to test the keyboard light is working fine.
完成的
添加一条评论
Resetting SMC helped me to restore backlight on MacBook Pro 2016:
http://osxdaily.com/2010/03/24/when-and-...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Winston Daigle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 30,954
