跳转到主内容
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
Why doesn't the MacMini2,1 support El Captain?
Hello,
Why doesn't the Mac mini 2,1 support El Captain?
If it has 2gb of ram, 2.0ghz C2D and a 64-Bit EFI, shouldn't el captain run on this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Bump. Still can't find out any reason why it wouldn't work.
完成的
Bonjour, j'ai un MacMini 2,1 qui en 10.7 je cherche une solution en 10.9, 10.10 ou 10.11 Je suis en 4Go C2D 2GHz merci à tous
完成的
添加一条评论
1个答案
已选择的解决方案
Apple would have to write the code to do this and it isn't in their financial interest to write code for this old a machine and give it away. The whole idea is to make your machine obsolete so you have to buy a new one. Think of plastic contains like Zip Lock or Glad. They keep changing them so the tops and bottoms of older containers won't work together so you re forced to buy new ones. Why? Corporate greed ;-)
这个答案有帮助吗?
得分 2
2条评论:
Is it still possible to edit the PlatformSupport.plist file to get it to run that way?
完成的
Sounds like you are knowledgable enough to do it.
完成的
添加一条评论
添加你的答案
Gigabit87898 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 331
