跳转到主内容
加入维修社区 - 创建账户
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
Screen separating from case when opened and closed
I bought a used macbook pro 15" late 2008 and the screen is separating from the lid case when opening and closing. It looks like the glass is coming appart from the rubber part. I would add pictures but can not figure out how to do that. see http://stlouis.craigslist.org/sys/563210... . Can any tell me if it just needs to be re glued or does it need a new hinge or other part?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
My bet is that the frame broken on the left hand side about 1" up from the lower left hand corner and is allowing it to flex and pull the glass loose.
这个答案有帮助吗?
得分 1
添加一条评论
The Craigslist post was deleted, so I can't open it to see what's going on. From your description though, it sounds like the glass if coming out of the screen? If that's the case, then yes, it's just a simple reglueing of the glass to the lid. On an aluminum MacBook Pro the hinges are almost impossible to break. I've never actually had to replace a hinge on one, so I wouldn't give that too much thought.
这个答案有帮助吗?
得分 0
添加一条评论
stripped screw hole?
https://discussions.apple.com/thread/306...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 11
总计 1,066
