跳转到主内容
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
263 个问题 查看全部
Nintendo DSI Power LED "vanished" - where can I get a replacement?
The Power LED indicator on the outer shell (bottom front) somehow... well, I suppose fell out, though I have no idea how that could have happened.
The DSI seems to be working fine, but I now have no indicator telling me when the battery is charged, so would be good to replace that part, but not sure where to find it.
Any ideas where to find a replacement for the power indicator LED?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Can you post a picture? I'm guessing its most likely an Surface Mount LED, in which case you can get it as a generic electronics components, rather than as a "specific" Nintendo part. You'll just want to make sure that its the right voltage spec for the DSi's motherboard. Unless you have experience soldering SMD components, I would recommend taking it to a professional repair shop.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Iedi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 58
