跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
MacBook Power Button Failing to work
Hi,
The Powerbutton on my macbook is failing to work. When the macbook is on pressing the button has no effect, and when the macbook is off I often have to press the power button down for several minutes before it will begin to boot. Any ideas on how to fix this? Searching through the repair guides I didn't see one where I could remove the keyboard/power button.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Well we don't know which specific machine it is and it sounds like you have shorted out the keyboard with a liquid spill.
完成的
It's the late 2008 model, I'm not sure how much more information you need in terms of the model? The rest keyboard definitely hasn't been shorted out, and I don't believe I've ever gotten liquid on the device, I've wondered if maybe some debris/dust could've gotten into the area?
完成的
添加一条评论
1个答案
已选择的解决方案
Sounds like possibly the keyboard to logic board ribbon may not be fully seated. See step #18 of this guide:
MacBook Pro 15" Unibody Late 2008 and Early 2009 Logic Board Replacement
I use a piece of tape on the cable to help pull it into the slot and then push the lock down after it's fully seated..
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 179
