跳转到主内容
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
139 个问题 查看全部
Possible to unplug camera and microphone(s)?
Is it possible to unplug the camera and microphone(s) on the 12" Retina Macbook?
I've used past iFixit guides to do this on older Apple devices. For example, in these Macbook Pro teardowns you can see where to disconnect the iSight camera and microphone.
Does anyone know if this is possible on 12" Retina Macbooks?
MacBook Pro 13" Retina Display Early 2015 显示组件图片
指南
MacBook Pro (13英寸, 带有Retina显示屏, 2015早期) 显示组件更换
难度:
中等
30 minutes - 1 hour
MacBook Pro 13" Retina Display Early 2015 双麦克风组件图片
指南
更换MacBook Pro 13'' Retina显示器2015早期版本的双麦克风组件
难度:
中等
40 minutes - 1 hour
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thanks for the advice, Dan & Larry. I realize that tape/glue/etc is commonly used to "disable" these, but I'd prefer a hardware solution if one is possible -- and it has been possible with other Apple notebooks.
Checking the teardowns for last year's model, it looks like the microphones are unpluggable (and that this doesn't disable the audio jack itself, since that's a separate step). But I haven't been able to find anything similar for the iSight camera unfortunately.
完成的
添加一条评论
3个答案
最有帮助的答案
Your only hope here is tape to cover the iSight camera lens & a cut off head phone plug to kill the internal microphone!
This series uses a highly intergraded architecture to such a point there is no means to disconnect internally the camera or microphone physically.
With that said why are you worried? Unless someone has direct access to your system to RAT it, there is no means to spy on you without you knowing.
Besides you can always turn the system off or put it to sleep mode ;-}
这个答案有帮助吗?
得分 2
添加一条评论
Are you trying to simply disable them or replace them? If you just want to disable them, use black tape for the camera and perhaps unsolder the microphone if it's not on a connector somewhere. Or just use glue or tape.
这个答案有帮助吗?
得分 1
添加一条评论
I had no problem disconnecting the cables on my 11" MacBook.
Furthermore, I have done the same on two Dell models.
这个答案有帮助吗?
得分 0
1条评论:
Very different animal here ;-}
This series of MacBook is very different than your older MacBook (retina Vs non-retina).
完成的
添加一条评论
添加你的答案
wizfish mcfrabblegabben 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 1,372
