跳转到主内容
Fan connector glued to the motherboard?
http://www.l2order.com/pictures/1820_L3....
It's this part. It's attached to the fan itself but it isn't attached to the motherboard.
If I press down the connector to the motherboard the fan works, but my question is could i glue it to the motherboard? And If I would, I would save 40 bucks but I'm not sure whether the glue could damage the motherboard itself
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
When you press down the metal contacts are completed thus enabling electrical flow. If you can clamp it down so that connections are made then use very small amount of glue to hold the edges in place you might be able to get it work.
Here are some other excellent solutions: I popped off the fan connection from the logic board...Fix?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Albertas Ensteinas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 960
