跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 个问题 查看全部
VESA Mount Removal, Install new Foot
Hi,
I work for a school, and we recently purchased 5 of the 5k 27" iMacs. I am currently away and didn't have anything to do with the purchase. My team has ordered the iMacs with the VESA mounts as they thought they would be an accessory in the box.
Apple won't return them, or provide feet. So I wanted to know if I purchased feet for these iMacs. Internally is the machine the same, is the other end of the VESA mount attached to the mechanism? Or have apple removed the mech in these models and attached the VESA straight to the rear housing?
Thanks
Garrett
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Hello Garret.
Sorry if I am repeating myself but I am desperate to be able to replace the foot with a VESA mount. Do you have any of the 5 VESA mounts and hardware left so I can purchase on from you?
I look forward to hearing from you.
完成的
Many years late, but I'm looking to try and convert my later 2013 27" imac to VESA and stumbled upon this post. If you still have any of thee available I'd be interested. Thanks
完成的
添加一条评论
4个答案
已选择的解决方案
It was a lot of work, had to buy the mechanism too as they removed the spring mech and replaced with a plate. Also needed to buy the screws to mount the stand to the new mech.
M3 x 8mm Torx Pan Head Screws - A2
这个答案有帮助吗?
得分 3
3条评论:
Hi again Garret... would you mind sharing where did you get all the parts you need for the mount of your bases? (if i understood correctly.. you want to have the original stand in L shape instead of the VESA mount that the units came with... right?)
Thank you!
完成的
Garrett ordered the standard foot and hinge plate to replace the VESA mounts to regain the standard foot as he got the wrong version of the iMac's that he wanted.
The first image is the VESA mount plate (which you can't get) and the second is the hinge unit which can be ordered as a spare! He also needed some screws and the foot, both of which can be ordered as well.
完成的
Hello.
I am very interested to hear if you able to get parts and instal the VESA mount. I am desperately trying to figure out how I can do this to my iMac 2014.
完成的
添加一条评论
最有帮助的答案
This one has to be torn down to get to it. See this answer which is basically your question in reverse: Is the stand removable?
这个答案有帮助吗?
得分 3
8条评论:
Another option here is to get a VESA foot stand while not the same as the Apple Foot, it should allow you to at least use the systems. Frankly, in a school environment you may find having the mount bolted down so the systems don't grow feet and walk away ;-}
完成的
Thanks Dan, I got the apple foot and just replaced them myself =)
完成的
Wow! That was a lot of work!
Save the VESA hardware you took out. There're people who would buy the parts as they can't be bought!
完成的
Like me, for example. Can I please buy the VESA mount hardware??
完成的
AND ME!!!! CAN YOU SELL ME ONE?
Garret... do you know if this mounts might fit my computer?
My iMac is a late 2014 27" 5k... are those computers the same model or compatible?
I would think and hope that if your computers are 2015 or 2016 models that Apple did not change the configuration yet... i have looked at options out there and none of them is the one i need... my neck is getting problems because the screen is too high... and i refuse to build a platform to raise my chair, and even worst would be to cut a hole in my desk in order to fit it in there... im a sucker for aesthetics.
so.. can you help Garret? how can securely and safely contact you?
Thank you!
MAC
完成的
显示更多的3条评论
添加一条评论
Hello,
I got excactly the same problem.
Have bought iMac27 (2017 Modell) with VESA mount withiut knowing that it comes wirhout stand. Seller refuses to take it back.
@Garret: did you succesfully mounted the original apple stand by yourself? Where did you get the original stand and the mechanics (and maybe the screws)?
Is the imac tiltable with your setup?
Andre@fluxguide.com
这个答案有帮助吗?
得分 1
2条评论:
Hi Peter,
It worked on the 5 we had at the school. They were all apple original parts.
I had to buy a stand, the mechanism (the part with the springs that makes it tiltable) and the screws to fix the stand to the mechanism.
I had to do quite a bit of shopping around to find it, I had most of my success on the website AliExpress.com and had the parts shipped from china.
Just a quick search I found.
Stand -
http://s.aliexpress.com/VFjiaMni
Mechanism -
http://s.aliexpress.com/3yYr6FZJ
If you need any help with the replacement, my email is garrett@garrettmacarthur.com
Thanks
Garrett
完成的
Hi Garrett,, can you please tell me how did you install the new mechanism and stand ?? how did u open the imac ? did you have to open it all up ? if you have a tutorial video that would be great
Regards,
Samar
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Garrett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 11,099
