Fixing the setting dial on GE Model WSXH208H3WW washing machine
There are 2 parts to the dial: one part (1.) that seems to be the dial that actually controls the setting, and the other part, underneath, (2.) that has the arrow on it that points to the setting. The second part can be accidentally turned independently from the first part, which is what caused the problem. The part with the arrow turned so it does not point to the right place in the cycle. The manual doesn't cover this that I can see. I need to know how to fix the dial so it points to the right place, and if possible, so it can't get knocked off again. (Possibly by removing the second part of the dial?)
6条评论
Here's how to add images: 在已经存在的问题里加入图片
由 mayer 完成的
Thank you for the tip!
由 selkie305 完成的
Please check that number as it brings up a microwave oven.
由 mayer 完成的
That's weird. It's the number that's on my washer. And I had an online chat with GE about it, in which they sent me the manual (good, but no help for this issue) and then told me to have a repair person look at it. It just seems like the kind of thing I should be able to do myself, as nothing seems to be broken.
由 selkie305 完成的
Omg. I have the same problem… the same exact problem! And can't find a straight answer on the entire internet anywhere. Everybody wants your money and tells you to call somebody for something that should be simple.
It's a d-a-m-n , there's got to be a way to align it and it shouldn't take somebody with a engineer degree to come do it.
This is ridiculous.
由 Cassie Stone 完成的
显示更多的1条评论
