跳转到主内容
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 个问题 查看全部
Why is my lcd showing a dim light after replacement
So I replaced my lcd on my iPad 4 everything seem to went well the first time but I noticed parts of the screen wasn't working so I took it apart again but this time when I reassembled it the lcd turned on but it was a dim black light and it wasn't showing no picture I'm not sure what to do please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Did you turn off the iPad when unplugging the LCD and replugging it?
I'm not 100% sure if unplugging the battery is required as well.
完成的
No I didn't completely turn it off but I did a hard reset and that still did not solve the problem
完成的
So right now it is showing no display but a dim backlight around the screen or something along the lines of that? Could be backlight fuse(s) blown or if unlucky LCD ribbon cable gone bad.
完成的
添加一条评论
1个答案
I have wrote a blog about the similar problem on iPhone. It may give you some help.
Why iPhone Screen Dim after Screen Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lateef ambali 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 70
