跳转到主内容
The APC RS 1000 is an uninterruptible power supply capable of delivering 600 Watts.
6 个问题 查看全部
after replacing the battery, all lights flasing and no o.p.
after replacing the battery after long non use all the lights are flashing and and no output
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
kvpselvam all LED's flashing at the same time indicates an internal fault. Time to take it apart and check the circuit boards and capacitors.
完成的
添加一条评论
1个答案
If the batteries have been replaced the UPS may need to charge them before it will respond correctly. Leave the UPS plugged in but off for 8 hours, then try again; before blaming a circuit board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kvpselvam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,400
