replace a a1212 with an A1261
hello, I have a macbook pro with the logic board a1212 broken , I would like to know if i can replace it with a A1261 (to have such a powerful pc).
thanks
No sorry they are not cross compatible , for starters the screens are different a1212 uses CFL bulb , while the a1261 uses LED bulb.
这个答案有帮助吗?
thank you, and whit a1229?
or any more powerful?
A white screen usually indicates a failed hard dive. Try disconnecting the drive from the logic board and booting from the original system installation optical disk.
这个答案有帮助吗?
you are right, thanks a lot!!!
Then you accepted the wrong answer ;-)
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 216
4条评论
or another more powerful, as the model a1229
由 davidegatt 完成的
Why do you think the logic board is broken?
由 mayer 完成的
the screen remains white after power, and did not work any recovery procedure (pram reset etc.)
由 davidegatt 完成的
由 davidegatt 完成的
