A horrible grinding noise during agitation
My washer is just over a year old and the noise it makes when it is agitating is unbearable. It washes good and does everything the way it suppose to, but the noise is the most unbearable screeching/grinding noise. What can it be? It has not been moved since we put it in.
2条评论
Thank you. It was the tub bearing
由 Mary D 完成的
Can you still use it if this happens? and what will happen if you keep using it?
由 jeff Bromley 完成的
