跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Does an iPhone 6+ screen works without home button flex cable
Hi,
I replaced the screen of my iPhone 6 plus. Now the flex cable of the home button in torn and i have got an instant black screen and no response at all. I was wondering if i broken my iPhone or i just have to replace the home button flex cable on the back of the metal plate? (it did work first, but because my ear speaker wasn't working i reopened it and then i destroyed the cable for the homebutton)
thanks in advance,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
No, you're phone should work just fine. Your Touch ID will never work again. But your phone should work just fine, also you can replace the button with an aftermarket one. Or you could just use assistive touch
iPhone 6 Plus Home键 更换
iPhone 6 and 6 Plus Home Button Assembly
If your phone is off, hook it up to iTunes. To see if it's still working fine. Should be. If it stays "black screen" either your display is broken, or you need to do a force restart
怎样强制重启iPhone5
I realize the guide is for the iPhone 5, I assure you the principle is the same
iPhone 6 and 6 Plus Home Button Assembly图片
产品
$19.99
iPhone 6 Plus Home键图片
指南
难度:
中等
30 minutes - 1 hour
iPhone 5图片
指南
怎样强制重启iPhone5
难度:
非常容易
30 seconds
这个答案有帮助吗?
得分 4
2条评论:
So there is no change i screwed the connectors attached to the motherboard? i think i just have to buy another screen then
完成的
Sounds like it. Unless you have a display you can test, to rule that out
完成的
添加一条评论
添加你的答案
iPhone56783 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,232
