screen presses buttons by itself
what is causing this? its phantom touches?
Has this tablet been dropped or repaired? It's definitely a touch issue with the digitizer itself. These issues can be software related, but they rarely are. Is there a warranty left on it by chance? I know a lot of repair shops that dont touch tablets like this because they are either not worth fixing since the repair may cost the same or more than a replacement or the parts are hard to find. If you have your data backed up, Id wipe the device and restore it to factory just as a last ditch effort.
这个答案有帮助吗?
I did reset it to factory condition and it did stop, but there is still a dead zone on the side that fits into keyboard. I don't use the keyboard except for a stand, so if I remove it I can flip it around and get around the dead zone. It's somewhat annoying but I can live with it.
Unfortunately, it does sound like a hardware failure. The good thing is you can work around it. I hope it doesnt get worse.
Go into your control panel , click hardware and sound, then click device manager under and find a option to delete touch device under human interface devices , or something that says that, i deleted it so I forgot what it’s called. So now my screen doesn’t touch by itself .
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 2,592
1条评论
my rca viking pro will not work if i drtatch the keyboard so therefor i am unable to use touch screen it completly stopped
由 michelle rakes 完成的
