跳转到主内容
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
screen presses buttons by itself
what is causing this? its phantom touches?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
my rca viking pro will not work if i drtatch the keyboard so therefor i am unable to use touch screen it completly stopped
完成的
添加一条评论
2个答案
已选择的解决方案
Has this tablet been dropped or repaired? It's definitely a touch issue with the digitizer itself. These issues can be software related, but they rarely are. Is there a warranty left on it by chance? I know a lot of repair shops that dont touch tablets like this because they are either not worth fixing since the repair may cost the same or more than a replacement or the parts are hard to find. If you have your data backed up, Id wipe the device and restore it to factory just as a last ditch effort.
这个答案有帮助吗?
得分 1
2条评论:
I did reset it to factory condition and it did stop, but there is still a dead zone on the side that fits into keyboard. I don't use the keyboard except for a stand, so if I remove it I can flip it around and get around the dead zone. It's somewhat annoying but I can live with it.
完成的
Unfortunately, it does sound like a hardware failure. The good thing is you can work around it. I hope it doesnt get worse.
完成的
添加一条评论
Go into your control panel , click hardware and sound, then click device manager under and find a option to delete touch device under human interface devices , or something that says that, i deleted it so I forgot what it’s called. So now my screen doesn’t touch by itself .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Susan Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,613
