跳转到主内容
加入维修社区 - 创建账户
D5100 发布于 2011 年 4 月,作为尼康广受欢迎的消费级数码单反相机之一,用以取代 D5000。它配备了可更换的尼康 F 卡口镜头。
Why won't my shutter work?
I was traveling with my camera and when I went to use it this error appeared.
Error: press shutter release button again. I did and it didn't work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Have you tried a hard reset?
Press the two buttons on the back of the camera with a green dot by them. For the 5100 they should be "Menu" and "Information".
My D5300 does this sometimes but I know what causes it - I have a portrait battery grip and when the tripod is hooked up, if I pick it up by the camera (and not by the tripod), the weight of the tripod pulls the grip downwards and interrupts the battery connection, so the camera has shut off without powering down. This may be irrelevant to your problem but it's worth knowing.
It could just be that you shutter has reached its end of life. You can check the life expectancy of the D5100 shutter here
这个答案有帮助吗?
得分 1
添加一条评论
you could try cleaning the shutter gears. following this guide
http://www.instructables.com/id/How-to-f...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michelle Houston 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 4,282
