跳转到主内容
加入维修社区 - 创建账户
One key has changed function
Hi,
This macbook pro had a little bit of water damage from using in the bathroom.
Everything works fine except one key... The @/# key has now the function "volume up".
How is this possible? Fixable? Can i change the function from settings?
Thx for your help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Using it in the bathroom !?!?! Thats not the best place to use your system.
Sadly this is not an easy fix what happened here is the soapy water got into the keyboard onto the switching elements damaging them. You will need to replace the keyboard to do this right. This is a very big job as the entire system needs to come apart. Here is the IFIXIT guide to gain access to the uppercase: MacBook Pro 13" Retina Display Late 2012 Upper Case Replacement. At which point you could take the keyboard out of the upper case and try to clean it or replace just the keyboard, or just replace the upper case.
As to how the keyboard works it uses a cross bar system (X & Y grid) so if you damage the contact board you can cause mis-keys as you encountered. Soapy water is corrosive which is why it got damaged.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mattis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 126
