How to set injector pump timing
How do I set the timing on a injector pump installation?
As mentioned, change your user name first.
You don't set timing of your injectors. The computer is responsible for energizing the injectors. Typically there is a crankshaft position sensor and other inputs that provide input to the computer to determine when and how long to energize. Basically, you install the injectors and start the car; the computer does the rest.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 307
Besides changing your user name you also want to be a bit more descriptive. What 6.9 L engine? What vehicle? Why?
由 oldturkey03 完成的
Late 90's Chevy Pick up, Suburban, Hummer?
由 LS Computer Systems 完成的
