跳转到主内容
加入维修社区 - 创建账户
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
Rear camera's and flashlight not working
At first the camera app would just shut down, so of course I restarted the phone. Then the camera app was working but it was fixed in selfie mode. I was not able to use the rear camera or the flash light. The rest of the phone is working just fine but I can't access the rear camera of the phone in apps either.
When I press the four circle icon the the camera app, it allows me to choose between the selfie cam (This one is selected) and adding a camera. When I choose to add a camera I get the option to add photo booth.
I already tried to restore the default camera setting but it didn't help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
5条评论
same problem here!!
please help!
i am going to order a new camera and replace it than let s see what happens.
完成的
Same problem please help me
完成的
restart your camera and immediately open cam, it will work, htc having overheating issue in 816 desire too
完成的
Even my m9 plus has the same issue.Again it happened on the M7 and M8 I had before.Infact from now even if the HTC is $1,I can't but HTC any more.
完成的
so my htc one e8 have same problem , did one of u guys fix it???and how?? please answer and help me
完成的
添加一条评论
3个答案
最有帮助的答案
Sir I have a same prblm flash and rear camera nt working how can get back my camera help me
这个答案有帮助吗?
得分 1
添加一条评论
It is a hardware issue with the camera itself. Its a very easy repair to do. Order a replacement camera and you should be able to swap it in a matter of minutes. Because iFixit rocks, there is already a very detailed thread on this:
How to Replace Rear Camera Module?
这个答案有帮助吗?
得分 0
添加一条评论
htc d820n back cemra option is no hilighted
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Frank Vlaar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 11,297
