跳转到主内容
Small rectangular magnet: not in procedure
I followed these instructions to replace hard drive in an iBook G4 Late 2004. Upon finishing, I found a small, stray magnet about 3/4" x 1/4" on the work surface. I know it must have come from the interior of the iBook but it's not mentioned anywhere.
IBook now starts to power on, but fails to boot, even from an external FireWire drive with a copy of the original disk.
Any suggestions?
Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Found the answer. Apparently this magnet sits near the optical drive and acts as an activator for sleep function.
这个答案有帮助吗?
得分 1
1条评论:
Now that you have your answer please accept it to allow closing the question. Thank you +
完成的
添加一条评论
最有帮助的答案
Although tjod is correct about the magnet it has nothing to do with your Book not starting. Your new hard drive needs to formatted and a system installed on it. Use Disk Utilities on your installation disk to format.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for catching that -- read the question to quickly and thought he had completed the repair. +
完成的
添加一条评论
添加你的答案
tjod 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 785
