跳转到主内容
加入维修社区 - 创建账户
2.3GHz、2.6GHz 或 2.7GHz 四核 Intel Core i7 处理器(Turbo Boost 最高可达 3.7GHz),配备 6MB 共享三级缓存。
Which specific resistor for component 'L8300' on MacBook?
I fried a resistor attempting to clear out some water damage on my logic board. It's the one at the bottom of this photo: (edit: see better images added below)
According the the board diagram and spec, I think it's L8300, which is labelled on the spec as 'FERR-220-OHM' and '0805'. However, when I search on digikey our mouser there are hundreds of matches. Does anyone know which one is the right component, and any tips for replacement?
Thanks!
Edit - better images as requested...
Highlight on (stock) photo:
Board diagram component that I think is the right one:
Schematic identifier corresponding to board diagram component:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
@petemill "the one at the bottom of this photo" is really not descriptive. Post an image where you mark the component so that we can check which one it is. You say that you " think it's L8330" that needs to always verified. L8330 does not show up in my schematics. Let us know what the logic board 820-XXXX number is. Reference designator "L" means that the component is an inductor. 0805 is the package size of 0.08" x 0.05" of the component.
这个答案有帮助吗?
得分 5
6条评论:
@oldturkey03 thank you for your comment and your advice on how to ask the question better. My mistake, the component is L8300 (not L8330)! I've added 3 photos: one photo with the corresponding area highlighted (this is not my photo, but ifixit's photo), another with the corresponding board diagram location, and another with the schematic location. I hope this helps you help me better!
完成的
@oldturkey03 do you think this inductor is a good replacement? http://www.mouser.com/ds/2/54/RF2012A-77...
完成的
@petemill excellent edits and great idea to add the images. Yes, that inductor looks like it would work for your board.
完成的
Hello to every one , well it is been 9 years now , but seems this laptop still a great machine ! 15 retina A1398 from 2012 to 2015 !
About the component is a MI0805M221R-10 Ferrite Bead 220 OHM
in this days I was try to get a replace , but some are replacing with a simple wire .....what is this ferrite bead ?asking to AI I get this ....
A ferrite bead is a passive electronic component, essentially a lossy inductor, that suppresses high-frequency noise (like EMI and RFI) by converting electromagnetic energy into heat. It works by adding impedance to high-frequency signals while minimally affecting lower frequencies and DC power. Commonly seen on cables for computers and other electronics, ferrite beads are a simple and affordable way to filter noise and improve signal integrity in various circuits
I get a replace on a old similar board , but very cheap to by online too
hope can help some else in this days
Ciao
完成的
@analfabetag look at it this way and it is simplified. A capacitor stores energy in an electrical field. A Inductor stores energy in a magnetic field. You would use a capacitor to filter (smoothen:-) an electrical circuitry. A inductor will do the same in a magnetic field. Think about all the magnetic interferences you have within a circuit (think audio and video circuitry especially) A ferrite bead inductors primary function is EMI suppression while a wire would inductor is primary for filtering and energy storage. You will see Ferrite Bead inductors mostly on signal lines for noise filtering.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Peter Miller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 859
