跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Ear peice and proximity sensor not working
I replaced the headphone jack on my iPhone because I was not getting a good connection to various headphones. In putting it back together I must have not connected connector 3 correctly. I have tried a number of times to reconnect it. Does anyone have a photo of what it should look like or any suggestions as to what I may be doing wrong? If not what is my next step?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
Could be your connector? It is hard to notice, but sometimes they break and lift off the board slightly.
http://hectordtruong.blogspot.com/
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Here's a pic (the model in the pic is a 3GS, but the connector is the same in this instance):
It has a gold tip that should be completely in the connector. Make sure the locking bar is down once the gold tip is in there.
Have you tried restoring it, or can you not get that far?
If that doesn't fix the problem, it seems that the front panel/digitizer is broken.
If THAT doesn't fix the problem, all signs point to logic board.
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
I Must have knicked the #3 cable while putting it back together. I too purchased a new cable, and although it is not the easiest thing to replace I did do it and now everything works wonderfully.
这个答案有帮助吗?
得分 2
3条评论:
+great! now you can accept your own answer
完成的
+ (You forgot your tick pollytintop)
完成的
oops, thought it went on.
完成的
添加一条评论
Might not be the logic board. That ribbon cable is fickle. I ahd this problem and just bought the cable (proximity sensor cable) off of amazon and replaced it. There's a youtube video on how to do it (since it's not immediately obvious), and it's an easy repair.
Also, remember to always shut off your phone before you open it. Seems that the proximity sensor or the cable may be especially sensitive to that.
这个答案有帮助吗?
得分 1
1条评论:
完成的
添加一条评论
dam im such an idiot i was trying to lift the white part of the connector and not the black thing and i then chipped abit of the white part but it has not tottally fallen off and the ribbon still fits in there thankfully but i guess its damaged and now i know how to fix it properly
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 7,948
