GPU Upgrade for 20" iMac (mid 2007)
I have a 20" iMac (mid 2007) What is my upgrade path for the graphics card ?
I have a ATI Radeon HD 2400 XT with 128 MB of GDDR3 SDRAM in my system now. I would like 512 MB at least but 256 MB will do the job.
Apple only offered two graphics cards for this series:
So you could swap it out. But, before you do that are you sure you want to invest that much here? This is a really old system. Its limited to 6 GB of RAM and doesn't really run very well with the newest versions of OS-X.
Maybe its time to save the pennies to put into a newer system (new or used) instead of putting it into this system.
OK lets do it!
Here is the IFIXIT guide you will need to follow: iMac Intel 20" EMC 2133 and 2210 Video Card Replacement. You'll need to get thermal paste cleaner and fresh thermal paste when you remount the heat sink to the GPU chip. I would stick with the 256MB ATI Radeon HD 2600XT board.
As to upgrading the CPU I would recommend you do one upgrade at a time making sure the system is still working before moving on here:
Here's the IFIXIT guide you'll need to follow to upgrade the CPU: iMac Intel 20" EMC 2133 and 2210 CPU Replacement. Again you'll need to get thermal paste cleaner and fresh thermal paste when you remount the heat sink to the CPU chip.
The other two upgrades I would do here (I would do them first) is maxing the RAM to 6 GB, I would also upgrade the HD to a SSHD. Since your system is only a SATA II (3.0 GB/s) you'll need to make sure the drive you put in can run at SATA II. I recommend using a Seagate Desktop SSHD. If we look at the spec sheet here: Seagate Desktop SSHD spec sheet. Looking at the line: SATA Transfer Rates Supported (Gb/s) we can see your systems SATA port speed is supported. Make sure any drive you put in has SATA II (3.0 Gb/s) listed.
产品
$9.99
指南
难度:
中等
1 - 2 hours
指南
难度:
困难
1 - 2 hours
这个答案有帮助吗?
i was asking that because i found it and wanted to know if it was possible but the nVidia 8800 GS with 512 MB from the 24 inch work ?
There's a bit more than just plugging in the graphics board. The heat sink mounts and how the fan unit fits would need to be checked out.
I don't know of anyone trying an nVidia 8800 GS board in this system. Are you sure you want to risk damaging your system here? In case things don't quite fit.
i don't realy care it was given to me because the persone change for a new one but i will need heatsink form a 24 inch ? and whats is the exact port for the graphic card ? and the cpu can it be upgraded to Intel® Core™2 Extreme Processor X7900
Before you start do the math out can you do it all for less than $500. You can buy a used 2011 iMac 27" model for around $600 - 700 (US) used.
Due the high failure rate of these video cards, the law or supply and demand, it's a very high dollar replacement. Better to do s Dan said and go with the 2011.
My iMac 2007 27" came upgraded with a Samsung 850 EVO 250 GB SSD. Therefore I think it is irrelevant to look for SATA-2 drives, seems to work just fine with SATA-3 drives.
It also haves the ATI Radeon HD2600 with 256 MB.
Two problems with these machines:
You can not put more than 4 GB of RAM into them. (Yes, 6 is possible, but where you find 4 GB modules?) Why did Apple not put 4 slots into them?
The screen develops yellowish horizontal stripes. Cause is that the LEDs burn the plastic above them.
I would like to know which is the highest specified CPU that was proven to work in these machines.
这个答案有帮助吗?
The Samsung SSD is an auto sense so it will matchup with the systems limited SATA-II (3.0Gbps) I/O so you don’t need to worry. Most of the other vendors are now fixed SATA-III (6.0Gbps) drives so they don’t work effectively within the slower I/O SATA-II systems. Which is the point on why you need to be careful the drive is rated for SATA-II systems. Unless the spec sheet clearly states it don’t buy it.
So tell me why did the builder of your home didn’t add another floor? That’s the same argument with RAM slots! At the time this system was being designed the need for still higher RAM wasn’t an issue. Likewise the standards group didn’t design this module to expend beyond 4GB.
This system is limited to Core 2 Duo CPU’s it doesn’t offer the needed cooling or power for anything higher.
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 59
总计 18,129
