跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note 4 是一款于 2014 年 10 月发布的蜂窝智能手机。Galaxy Note 4 的型号为 SM-N910,美版型号包括 SM-N910A、SM-N910T、SM-N910V 或 SM-N910R4。
note 4 screen not turning on but buttons still light up
After opening up my note 4 and adjusting the gps antenna on it when i put it back together the screen no longer turns on but the buttons still lights up indicating that power is running to it can you guys give me a brief idea of what component i need to check out to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
The LCD cable plugs in behind the logic board. It probably went loose if you lifted up the logic board. You simply just need to plug it back in. It's a bit tricky to do.
这个答案有帮助吗?
得分 3
2条评论:
do u have a picture of which ones?
完成的
Check step 6 of this guide. You should be able to plug in the two cables. I think one is for the S-Pen and the other is for the digitizer + lcd.
三星Galaxy Note 4屏幕组件的更换
完成的
添加一条评论
添加你的答案
baconlover53 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 4,870
