跳转到主内容
加入维修社区 - 创建账户
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
iPad Lock Button doesn't work
I have sort of an odd problem that I was hoping someone in the community could give me a hand with. My iPad 4th gen wifi has some odd issues with the lock button. Not only does it not work (even after replacing the lock button/volume ribbon) when the iPad was in use the assistive touch menu would not even lock the device. I was wondering if that could indicate the problem being more logic-based or if it was perhaps a fault in the board that connects the headphone jack, cameras, and lock/volume buttons to the logic board?
Any help would be great.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Id try another lock ribbon cable and see if you cant find a replacement board that the lock ribbon cable plugs into. I think they are separate. I cant remember off the top of my head, if they are or not. I had the exact same issue and it was the lock ribbon cable needed replacing.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the help, I'll give it a shot.
完成的
添加一条评论
添加你的答案
Preston Stone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 172
