跳转到主内容
加入维修社区 - 创建账户
2015年三月发布的MacBook 11吋使用第五代intel i5/i7处理器,並且拥有比前代稍佳的性能与电池寿命。
iSight camera not working
Hello all,
I have an inconvenient problem the Macbook Air 11 Early 2015 iSight camera seems not to work when I use FaceTime all I get is a black screen with a blinking LED by the camera.
i did a system reset but nothing happened
I need a final solution
Some answers talk about the Cable connected between the iSight camera and logic board is not connected
Please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
This machine may still be under warranty or if it's just out Apple may allow you to add AppleCare. What's the purchase date? If you don't remember go here and input your serial number. If you registered it it my show if it is still covered: https://checkcoverage.apple.com
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
Using this IFIXIT guide: MacBook Air 11" Early 2015 Display Replacement Follow the first group of steps (Steps 1 thru 3). Then jump down to Step 7 making sure its connected.
If you see any damage due to dampness you may need to clean the logic board and connector with a moist cotton swab with a good quality isopropyl alcohol (85% or better).
If that doesn't fix it I suspect your iSight camera is bad and that will require replacing the full lid assembly unless you can find someone with the needed skills and parts to replace the camera unit from a junker system.
这个答案有帮助吗?
得分 3
添加一条评论
How was this solved? My camera is not working, it is showing the green blinker only.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mahmoud 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 2,184
