跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
iPhone Screen Dull After LCD Replacement
After replacing my LCD screen the screen is very dull. I can barely pick out what is on it. I tried resetting the phone, changing the brightness in the settings and upgrading to the newest software after a factory restore and I'm still having the same problem !?!?! HELP PLEASE !!!!!!!!!!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
hmmm. looks like the back light is blown up. can you try to test it with any KNOWN working one? if so and the screen is still dark, you might need to see specialist, more here:
No backlight after complete Touch/LCD replacement?
it is for 3Gs, but same symptoms.
if i was you, i would try to check connections. it might just be a loose connector.
get back with any progress, so we can finish this off...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Morgan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,465
