跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
No backlight after complete Touch/LCD replacement?
I repaired an iPhone using a complete Touch/LCD and the phone seems to work except for the backlight. As there is only three cables from the screen to the rest I wonder which one of these that powers the backlight?
Second question could of course be - is there any risk that I damage something else during the process that could effect the backlight?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
hi peter, i edited your post - i think that "LSD replacement" is something different ;-)
the backlight and the lcd are powered by the same connector (1)
to the second question:
did you remove the battery while installing the lcd ?
if not, sure - it's possible that you shorted something
i only see 3 possible faults:
  1. the connector isn't plugged in correctly
  2. the backlight of the lcd does not work
  3. the coil for the backlight died while the connector shorted the contacts
这个答案有帮助吗?
得分 2
2条评论:
Where is the "coil for the backlight"?
完成的
I think you mean that coil and fix?
http://img686.imageshack.us/img686/9351/...
完成的
添加一条评论
If your iphone screen was working (backlight) prior to screen change then a short has occured and the coil is fried. Check out 'backlight coil replacement 3gs' (and other combinations) on ebay -there are guys who will fix your phone for £20.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Peter Karlberg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 27,188
