跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Weird lines on the back of the phone?
I have some weird lines on the back of my iPhone. It is there which says "Designed by Apple in California" even, like small scratchings. Even where the FCC logos are and just close to the lightning port.
However I haven't dropped the phone or even put it in a pocket with sharp objects. I've had it with a case since I bought it. Any idea whats causing this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Are these scratches having an effect on the function of the phone?
完成的
添加一条评论
2个答案
最有帮助的答案
Something it putting a lot of pressure on either that spot (like in a pocket) or on the charging port enough to strain/crack the back plastic body
这个答案有帮助吗?
得分 1
1条评论:
I think I agree with ethreal. Btw props on your work on this site
完成的
添加一条评论
Dirt/sand/any small particles that were trapped between the case and the phone. If they were moving enough to leave marks, then they may have also moved enough to have fallen out by now. Could also be a poorly manufactured case where excess flash from the injection mold or a seam in the plastic is rubbing in that area.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tharindu Weerasooriya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 282
