跳转到主内容
Repair manuals for tablets manufactured by Samsung, running operating systems other than Android.
65 个问题 查看全部
lcd show weird colors
Hi there everyone,
''So i repair for living mostly i find by myself what the problem is but with this one i got no idea what i could be.
so i got an client with a Samsung tab Model; GT-N8010 he come over with this tablet showing strange colors (like the colors are negative) on the lcd.
no problem i replace the lcd , everything worked perfect colors are perfect.
after 2-3 weeks client comes over again with the same issue, ofcourse hes little bit mad because he payed the repair.
thing i hope you can do answer for me:
''-can it be from dropping the tablet on ground?
-could it be lcd cable?
-is it an hardware/software problem?
-did someone experience this ever before?
thing i tried:
'''-factory reset
-soft reset
-try to put negative colors on to see ( that even worse)
sorry for my langue (im dutch)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Clean LCD cable with isopropyl alcohol. At least 90% or better with battery unplugged. Make sure you definitely tape the LCD ribbon cable / connector down to reduce chances of it moving around.
Hardware problem. Most of the time it is the LCD cable. You probably didn't need to replace the LCD if you didn't try cleaning / replugging it firstly.
1. Can it be from dropping the tablet on ground?
Yes that is very possible.
2. Could it be LCD cable?
Yes, another possibility.
- Is it an hardware/software problem?
Hardware issue.
- Did someone experience this ever before?
Yes. Have had a few clients come in with this issue. I solved it by replugging / cleaning the LCD ribbon cable and making sure there is a sufficient amount of tape so that the cable / connector can't move around.
这个答案有帮助吗?
得分 2
1条评论:
thanks for the reply, gone order new lcd cable , already tried to unplug and with 99% isoprop so i guess last chance is lcd cable otherwise hardware or client droped tab...
完成的
添加一条评论
This is a problem with the LCD screen. Here is one: http://www.ebay.com/itm/for-Samsung-Gala...
这个答案有帮助吗?
得分 0
1条评论:
i don't think so, i replaced the lcd and the same problem just returned after 3 weeks.
完成的
添加一条评论
添加你的答案
Brian ifikske 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 40
总计 413
