跳转到主内容
Released March 2006, identified by model D620 on the keyboard bezel.
39 个问题 查看全部
starts but stops by login, fan is not running
it starts but by the time it gets to windows login screen it shuts off.the fan doesnt seem to come on,battery is fine,is it shuting down due to it getting hot or is there a safety switch of some kind
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
Hi, I am providing you with a link to Dell Support in the hopes they can help you. I would start in the left column under product support first. Good luck.
http://support.dell.com/support/index.as...
这个答案有帮助吗?
得分 3
1条评论:
完成的
添加一条评论
Remove the keyboard, turn on the laptop.
Touch the heat sink while the laptop is turning on.
If it's getting very hot but the cooling fan doesn't spin, try replacing the fan.
How to remove keyboard from Dell Latitude D620 laptop
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
1st thing to do is check if laptop fan and fins are clogged up with dust which are preventing it from spinning, then look at above suggestions
这个答案有帮助吗?
得分 2
添加一条评论
had this a few times myself. make sure the fan connector did not come out of it's socket and that the socket itself is sitting flush and that both pins are making their way through the socket and into the fan connector.
common issue with the D series.
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
This is definitely a overheating problem. try using laptop ventilation stand to save your laptop from getting over heated.
Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cary clague 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 6,087
