跳转到主内容
加入维修社区 - 创建账户
The Bose SoundLink Color is a Bluetooth speaker, designed as a more affordable and portable alternative to the SoundLink Mini.
My speaker won't make sound.
Help! My SoundLink Color says it is connected, but there is no music playing. What could be causing this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
12条评论
My speaker will not play but seems to activate playing my itunes music from my computer. I am listening to the radio on my computer and want to have the radio play through the Bose speakers from my mac.... Any suggestions ?
完成的
Blame apple.
完成的
If the speaker seems to connect but will not play audio, try restarting it with the following procedure:
Connect the speaker to power.
Press and hold the Multi-function button for 10 seconds.
While continuing to hold the button, unplug the speaker from power. Then release the Multi-function button.
To completely reset the speaker, press and hold the Power button for 10 seconds until the speaker turns off.
完成的
Worked like a charm, even for a 66 year old grandmother! Thank you so very much. God Bless You Big Time!!!
完成的
Thank you Nigel. It worked for me too.
完成的
显示更多的7条评论
添加一条评论
5个答案
已选择的解决方案
Bose SoundLink Color Troubleshooting
No audio from a Bluetooth® device
Applies to: SoundLink Color Bluetooth® speaker
To resolve this issue, please try the following:
Make sure your device is connected to the speaker
Make sure the speaker is not muted and the volume is up
Make sure your Bluetooth device is playing audio, and the volume is up
Your Bluetooth device may be out of range. Try moving it closer to the speaker
Move your Bluetooth device and/or the speaker away from other devices that generate electromagnetic interference. Examples are cordless phones, microwave ovens, wireless network routers, or other Bluetooth devices
If possible, turn off all other nearby Bluetooth devices or disable their Bluetooth functionality
Turn the speaker off and back on
If you're hearing audio from a different Bluetooth device, pause audio on that device.
这个答案有帮助吗?
得分 1
3条评论:
I had gone through all of these steps to no avail. I finally unpaired my apple watch as well. I paired the Bose device and it worked. Then I paired my apple watch back. It was a moderate hassle because I had to go through the watch settings to get it set up again. Thanks.
完成的
I'm also having the same issue and these steps did not fix it. In addition the sound on my iPhone will not play when connected to bluetooth now
完成的
I had the same issue and I fixed it with the Bose app, I needed to set some things up using the app for it to work
完成的
添加一条评论
最有帮助的答案
I had the same issue, and tried all the same advice. In desperation, i deleted all my blue tooth connections to Bose speaker. Reset the speakers to start from scratch so it was like new.
Paired all my devices to the speaker, and all worked fine. Not sure why it failed to play, and strange it was all my iPhone and iPad not working, but air-Pods worked all the time.!!
这个答案有帮助吗?
得分 2
1条评论:
My Bose won't play Cds but is ejecting OK.. comes up with not Playable even when I put a new CD in. 5yrs old
完成的
添加一条评论
Hi, make sure who have the latest Bose app on the phone as well, I found by deleting the app and re downloaded it sometimes resets the software. I noticed this a couple of times after Apple updated their software.
good luck.
这个答案有帮助吗?
得分 1
添加一条评论
Turn your phone off and on, i tried everything other than that and it worked once i did!
这个答案有帮助吗?
得分 1
1条评论:
I second that, restarting the phone is key. I had this exact problem and i fixed it. Thank you all.
完成的
添加一条评论
I have tried your suggested instruction but still no sound from speaker
这个答案有帮助吗?
得分 0
1条评论:
Delete the app forever !!!
完成的
添加一条评论
添加你的答案
Brett Horstketter 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 50
过去 30 天: 218
总计 75,287
