跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
How do I replace the screen on the 2010 MacBook Pro?
I have the replacement glass, however do not know how to get to remove the original glass.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
This question was migrated from http://meta.ifixit.com/.
完成的
添加一条评论
2个答案
已选择的解决方案
Here are the directions for the Unibody screen removal: MacBook Pro 15" Unibody Mid 2010 Front Display Glass Replacement
Note you will need a heat gun and the suction cups help.
Here's the heat gun I use: Heat Gun
Here's the suction cups: Heavy-Duty Suction Cups (Pair)
Two 2.25" diameter suction cups used for lifting display glass off Aluminum iMacs. A must-have tool when repairing broken, cracked, or shattered iMac screens. Get a good grip on glass panels and displays. Easy and quick to use. Suitable for DIY fixers and repair professionals.图片
产品
$14.95
Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C).图片
产品
Heat Gun
$29.99
这个答案有帮助吗?
得分 2
1条评论:
Descriptive Answer. +
完成的
添加一条评论
look here
LCD Removal Instructions: Apple Macbook Pro they all come apart about the same.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
这个答案有帮助吗?
得分 0
1条评论:
This link appears to be for the older non-unibody MBP.
完成的
添加一条评论
添加你的答案
meverett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 10,158
