跳转到主内容
加入维修社区 - 创建账户
2.26 or 2.4 GHz / White plastic unibody enclosure
Mac os x install problems
So I've recently resurected a broken macbook, replaced new parts and it was fully working, although the hard drive had the old mac os x and bunch of files that weren't mine, so I decided to delete it all via disk utility ant reinstall a new mac os from usb. I made a bootable usb through transmac but the computer won't recognize it while booting while holding option button.. The recovery menu offers to install Lion mac os, but it fails with message "This item is temporarily unavailable. Please try again later" or smth like that and I'm stuck with no mac os x.. I have another macbook laptop, which has tiger 10.4 operating system and I can't make a bootable usb with that old mac because it doesn't support most of the programs, could someone help?
by the way, when going into recovery menu, Safari glitches and apple website with "el capitan" update won't open, If I press "upgrade now" it simply wont ant website just crashes.. how could I install a mac os to that laptop? thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
btw I also get "an error occured while preparing the installation"
完成的
What were you booted from to be able to run Disk Utility and wipe it? This is really a lollypop that you dropped in the dirt and want someone else to clean it up for you! I'm sure you don't have what you need like the original 10.6.3 installation disk or a retail version of 10.6, right?
完成的
I don't have the original disk:( Old hard drive had an old mac os x installed already, so I wiped it and thought that I'd install a new mac os via usb like I used to do. But I get all kinds of different errors:( Biggest problem is, that macbook can't recognize the bootable usb stick
完成的
添加一条评论
1个答案
已选择的解决方案
It was my mistake, don't know why but the usb got recognised when I installed ISO mac os x instead of dmg file, now it recognised it and I succesfuly installed it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Albertas Ensteinas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,333
