orange pulse no repsonse from controller
i think my controller got water damage (thanks to my 2 year old). there was just a little bit of water near/in the charging port while it was charging. It didnt leak out water or anything. I have not seen anyone post anything similar to what it does. If i try to charge it, it glows orange for about a second and stops. it is unresponsive after. when you press the ps button nothing happens, not even from the light. it will only glow once until you disconnect the charger. Once you reconnect it will glow again. the factory reset button does not work and nothing i do will get it to work or connect to the ps4. is it the battery? or am i out of luck and have to buy a whole new controller? i dont have the money for a new one right now. thank you!
Was the controller on when it got spilled on?
由 Alex 完成的
no it was not on. it was either charging or fully charged at the time i believe.
由 chuck 完成的
My controller was working perfectly fine, then I used it on my MacBook Pro via USB and now when I plug it in to the PS4 it does the 1 yellow flash and nothing after that. I've tried multiple reset and pairing methods and one time I got it connected to the PS4 but the PS button was non responsive. Crazy thing is the controller still works fine with my mac so I know its not totally dead.
由 William Baxter 完成的
