跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
What part number and how do I replace the backlight?
The top 1/3 of my Imac 20" is darker than the rest of the screen. I assume I need to replace the backlight and potentially the entire display? Can someone help me figure out what the part would be that I need to order?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Is it the top 1/3 or top 1/2 of the screen? Does it fade from the middle and get darker as it goes to the top?
完成的
添加一条评论
4个答案
已选择的解决方案
Since ifixit dont seem to stock the inverter as s spare part I thought I'd mention that that well known auction site has inverters listed as low as US$20 so it may be an option for you to try for not much money
The LCD tear down guide on this site states
"During reassembly, the order of the inverter cables is interchangeable within each socket."
It may be possible to determine if it is the inverter or the CCFL's by swapping the upper and lower connectors... if the cables are long enough
WARNING - the CCFL operating voltage can easily exceed 1000V. Personal injury or damage to the iMac is possible if contact is made with this voltage
If the dark part of the screen moves it is the inverter and if it does not then it's the CCFL in the LCD.
It looks as though the LCD is the same/similar as used in the Dell SP2009Wc. If so The CCFL are edge mounted and there are 2ea top/bottom of the LCD. Looking at the cct diagram for the inverter suggests that the CCFL should run separately so 2 CCFL across the top not working suggests the inverter not the CCFL as I'd say it was unlikely 2 CCFL would fail at exactly same time... This suggests inverter to me...
UPDATE
My guides - Removing CCFL Assemblies from iMac Intel 20" EMC 2133 and 2210 LCD (part no LM201WE3) and Removing CCFL from iMac 20in LCD CCFL assembly were inspired by this question
iMac Intel 20" EMC 2133 and 2210 LCD Backlights (CCFL)图片
指南
iMac Intel 20" EMC 2133 and 2210 LCD Backlights (CCFL) Replacement
难度:
困难
45 minutes - 1 hour
iMac Intel 20" EMC 2133 and 2210 CCFL assembly图片
指南
难度:
困难
1 hour
这个答案有帮助吗?
得分 3
1条评论:
Great answer +
完成的
添加一条评论
Looks like you need a new LCD, but iFixit only sells the glass, you'll have to search elsewhere for that.
这个答案有帮助吗?
得分 0
添加一条评论
I took the display out to see what model it was and I have the LG.Philips display part number LM201WE3(TL)(F5). Should I try replacing just the CCFL or the entire display?
Are there other compatible models to make my parts search more broad?
这个答案有帮助吗?
得分 0
1条评论:
Hi Joe, the manufacturing part may assist you in finding the OEM supplier but I'd be you wont buy one that way..
If you can remove the CCFL assy it would be worth at least trying... Your description suggests that only part of the back light assy is failing. It could be a simple loose connection too.
The manuals have no detail on replacing the back lights...
It could be the inverter...?
The Mid 2007
LCD Assembly, 20” part no 661-4434
Inverter Board 922-8204
The early 2008
LCD Assembly, 20” part no 661-4671
Inverter Board 922-8507
HIH
完成的
添加一条评论
There are a couple of links to CCFL replacement on laptops but they will at least give some guidance and general idea of what is involved in replacing the CCFL.. still trying to get a specific procedure for you though
Link 1
Link 2
Quote from link 1, "The average life for a laptop backlight is on the order of 30,000 hours, or more than three years of 24 hour a day use. When the backlight in a laptop flickers or fails, it's more likely the inverter than the CCFL tube."
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe Nolan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 8,585
