跳转到主内容
加入维修社区 - 创建账户
Announced in October 2013, The Nikon D5300 is an upper-entry-level DSLR with a 24Mp DX-size sensor.
Camera files destination problem
Any time I take a pic with my camera and then insert the Sdcard to the Pc . , it creates a new folder for the stack of pics that I taked . How can I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What software are you using to view the contents of the card?
完成的
On pc I use Windows10 . I don't know the camera software.
完成的
添加一条评论
1个答案
已选择的解决方案
Your problem has nothing to do with the camera. The camera saves your images on the SD card in folders which are named 100NIKON, 101NIKON and so forth. Image files are given a sequential number from 0000 to 9999, and only when the file number rolls around from 9999 to 0000 a new folder is created on the card.
When using a windows PC to read the card, this is the folder/file structure you should see on the card.
However, when you copy the images to the Pictures folder on your computer, Windows tries to be helpful and creates so-called virtual folders by date - which can be rather annoying if you don't want this. This behavior can be defeated: in the folder window there's a dropdown button labelled Arrange by:, set this to Folder and the virtual folders that classify your pictures by date will disappear.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Nikon D5300 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 663
