跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
Graphics card upgrade on 27" iMac 2011?
Does anyone know what the next upgrade is of Graphics card? Currently running on AMD Radeon HD 6970M 1024MB
Apple have already done the free upgrade for faulty graphics cards but they can only upgrade to the same graphics card so i now have the same issue again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
Most of those boards just needed a simple reflow. I use an inexpensive ($70.00), 898D+ 2in1 SMD Rework Station Soldering Hot Air Welder ESD Tips BGA Nozzles KIT.
Then here's a short course on micro-soldering on this link for the high dollar one.. Hakko Microsoldering Starter Bundle
Hakko Microsoldering Starter Bundle图片
产品
$799.99
这个答案有帮助吗?
得分 4
1条评论:
BTW That's this GPU, with the recall, right:https://support.apple.com/en-us/HT203787
完成的
添加一条评论
Sadly, there is no higher graphics board for this series.
How long ago did you get the graphics board replaced? I would go back to the Apple Store with repair slip in hand. See if they can replace it again.
这个答案有帮助吗?
得分 3
添加一条评论
If your so willing, most nvidia mxm cards will work with the web driver... take a look at this.... https://www.ifixit.com/Story/18646/Succe...
这个答案有帮助吗?
得分 1
添加一条评论
This thread is a bit old but since it showed up on my Google search as I'm thinking about the same thing, here it is a link that might be better than using a non-supported card:
https://forums.macrumors.com/threads/201...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
lucy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 13,761
