The HP Deskjet F4480 Printer/Copier/Scanner. This printer was intended for home or small office use.
Prakhar Dikshit @prakhardikshit
声誉积分: 1
发帖于: 2016年5月16日
How can I remove the scanner part and make it use as a seperatw scanner. As I have another printer so I only need a scanner. Help me out.
这是一个好问题吗?
Brian Reeder @brianreeder
声誉积分: 1.5千
4
2
First just use it as a scanner and do not print to it then. Most Printer/scanner combinations do not separate. If you just want a Flatbed scanner then you will have to get one. Otherwise you have your answer.
这个答案有帮助吗?
1条评论:
Printer tells me "scanner Failure" unable to scan, copy or send fax.
由 George Reevie 完成的 2017年12月20日
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 197
